frankv569
- pittsburgh,pa
i ve been reading up on old questions and cannot seem to find exactly what i am searching for. the tranny on my 96 xj (aw4) seems to be goofing up.if i am driving along at about 45 mph or so, with the shifter in the o/d position and press in the gas to where you would think it should downshift to second and start to accelerate, it almost seems to upshift and bog down unless you floor it or manually downshift. im not sure if it is really upshifting - but it sure seems like it. also, i have been noticing that when im commuting on the highway (75 or so mph) on level ground , I can notice the tach keep raising 200-300 rpms or so and you can hear the rpms increase out of the blue with no load or throttle position change. i could understand it its the t/c unlocking and going 'down' into regular overdrive - but why if the load hasnt changed nor the speed? seems odd to me. it seems to be acting up like this more frequently. i have 30x950's and 3.55's. i changed the fluid out about 2-3 months ago with advanced auto parts brand of dex3 / merc fluid. is this fluid acceptable? is this an early warning of failure? what to do?? what to do?? it does seem to not act up as much in the regular drive position.
