iwannadie
- Gilbert, Az
So, I just wanted to rant and maybe get ideas on how to handle the situation.
My moms car was taken to a local shop, I know the owner/main guy through a local car forum. I've had minor work on the jeep done there over the years and he always has been honest and great about everything. My moms car is a 99 sable, it had a blown head gasket and I recommended she take it to this shop. The guy looked it over and wanted something like $800 to it which seemed worth while to me.
He gets the car and started working on it, later that day we got a call saying the head is warped slightly and a few bad valve seals. He said they use a local machine shop and got a good rate to do the work. He offered not to do the head work but said he would really rather do it just to be sure it's 100% so we do it. I wasn't shocked with the age of the car and hoped he was just being thorough and wanted the car running perfect. It brought the bill up to $1200.
My mom got the car back and I think the next day it was loosing coolant, bubbling out of the over flow bottle(closed cooling system). We call and they tow it back to the shop and call the next day to say it was a bad thermostat and is going to be about $100 to fix. I first don't like that if it was bad they didn't replace it while it was all apart, then I don't like that as the cause for the leak. How the bad thermostat caused a major leak the day after the head gasket repair and not one over heating problem before is beyond me. She pays for that to be done however and just decides to move on with the car.
A few days later, again coolant is bubbling out of the over flow bottle. They come again to tow it. They find this time that the over flow bottle has stripped threads. I just recently replaced the over flow bottle less than 2 months before they got the car. How the stripped threads were missed the 2 previous times in the shop and how they got stripped to me are a mystery. They offer to fix it for just the cost of the part this time after I told them I would replace the bottle myself rather than pay them for something that easy.
With the car back it was driven a few days then my mom said she saw tons of smoke out of the back of the car and it suddenly ran bad and died. They came and towed the car off the side of the road. They got it to their shop and found the lower radiator hose had burst and the car over heated so bad it shut itself off. They replaced the hose and it started but ran bad with signs of the head gasket blown and the water pump just gushing coolant. Basically now the engine ruined after just paying over $1300 to fix it.
Should I trust the guy and just accept the hose didn't show sign of wear before it suddenly blew and each previous issue was a mistake. Each time they had the car they said they drove it and let it idle to make sure nothing was leaking or going to go bad. They used at least a full tank of gas over the 3 times there. Would I be out of line to ask for an engine swap to be done at just the cost of parts?
