Update on the Iron Rock trackbar and bracket.
I ordered it by phone (couldnt get there website to accept my order for some reason) on a Monday, had a good conversation with the representative. He was very nice and knowledgable. They sent it out that day by FedEx and it arrived at my door on Thursday, packaged up well. The quality of the trackbar and bracket are top notch. I did have a couple issues during the install. First thing I noticed was that the hardware was too short for my liking. The axle end bolt and nut are metric grade 10.9 (equivalant to SAE grade 8), which is slightly larger than the stock bolt. The larger bolt worked out well for me because my holes were wallered out some. I cant say if you would have to redrill the holes if your holes were in better shape. Anyway, the bolt was just barely long enough to catch all the threads in the nut without any washers. The upper end of the trackbar has an SAE grade 8 bolt, I cant recall the size but its alot bigger than the bottom one. It was WAY too shrt. It barely caught half the threads in the nut with no washers. So I decided that I would need to replace at least the upper bolt with a longer one. I couldnt find a grade 8 the correct size so I settled for a grade 5. I feel ok with this because the bolt is under double shear and is still quite a bit bigger than the lower one so it wont be the weak link anyway. I also replaced the lower one with a longer bolt. Again, I couldnt find a 10.9 so I settled for a standard metric bolt. Im a little bothered by that and may change it for a 10.9 at some point but I dont think its all that bad because this bolt is still bigger then the one that came from the factory. So thats the first problem I had, hardware too short.
The last problem was the length of the TB. I have about 3" of lift. I specifically asked if their HD trackbar and drop bracket would work with that amount of lift and I was told that it should. When I got everything installed and centered, the TB was about 1/4" too long with the threads bottomed. Thts not a big deal and wouldve worked just fine but I have access to a metal cutting bandsaw table so I cut 3/4" off the bar and the threaded end. That worked great and gave me about 1/2" of adjustment to play with. I dont think cutting 3/4" off the threaded end degraded the strength at all as there is still about 2.5" of threads engaged in the bar. So the last problem I had, the TB is slightly too long for 3" of lift.
One other thing worth mentioning but wasnt really a problem for me was the lack of directions. There were none. Its not rocket science to install the bracket and TB but I thought it was strange to not include ANY directions at all, not even any torque specs. I would think it to be a good idea to include at least the torque specs.
The good news is that my Jeep handles so much better now than it did with the factory bracket and RE 1600 TB. I had a bit of shaking after hitting pot holes and expansion joints on the interstate. that is now completely gone. I also had a bit of bump steer when going over humps, that is gone now. It also feel a bit tighter in turns. I dont know if the RE TB was the issue or the factory bracket and I would probably still be driving it that way had the RE TB not started to pop the other day, either way, this setup seems to be much sturdier.
All in all, I'll say very good service, good price, quality product but there are a couple things to work out. I recommend this TB.
I didnt take any pics because basically, nothing stood out as being outstanding, either in a good way or bad way. It is exactly what their site says it is, 1.25" solid bar stock, with 1/4" flat stock bracket, The welds were deep and solid, all powder coated gloss black, two piece poly bushings and steel sleeves.
I will send an email to Iron Rock and let them know of the problems I had. They are easy fixes so I suspect they will look into them and if they see them as problems, they should fix them.
