PepperRed said:You drop the rear...nothing happen's.
You drop the front, and your pumpkin starts playing tag with your oil pan..
I would recommend F-150 springs up front with 2 full coil revolutions cut off, and remove one of your rear leafs besides the main and overload.
Edit: that should give you a stiffer ride up front with about 1.5 or 2" lower than stock. The stiffer F-150 springs will prevent the axle from touching the oil pan.
I wouldn't bet my oil pan (or engine) on that. The stiffer spring rate would make it less likely, but wouldn't prevent it on one of those surprise dips we've all hit at some time or another on a poorly lit road.PepperRed said:... The stiffer F-150 springs will prevent the axle from touching the oil pan.
silverslk said:My buddies MJ we did a spring over and it raised it about 5-5.5". Come to think of it......what would MJ springs with spring under do?????
lowrange2 said:Think about cutting the spring... The coil is made to have more or less a flat spot on top for the spring to seat... If you cut it off then the flat spot will be gone. YOu're gunna have fun trying to get it to stay put! I'd still heat them.
passxj said:You can cut the stock coils. Its not dangerous or ghetto. As you cut the coils, you lose height and gain spring rate. You need to watch clearance issues though. Pull the springs and then raise and lower the front of the XJ without springs to see what problems you'll have.
Spring under in the rear will lower it too much. I'd say do the spring under with an AAL or extended shackle. You could even use a nice lifted springpack with a spring under. If all you're planning is street use, look for a 2wd. The 2wd's are very inexpensive.
Don't listen to all the Naysayers. A lowered XJ would make a great daily driver.
silent_bob_662001 said:I can't believe no one has Questioned what this would to his driveline angles?
bjoehandley said:What ever you do, PLEASE DON'T DO THIS!!!!!!!!!!!!!!!!!!!!!
jwtrapper said:That has nothing to do with lowering an XJ..... But hey thats a cool Probe, I bet its ubber fast!!
