- Hammertown, USA
So just to be clear... your saying that you would rather lift a tire than keep it on the ground simply because the coil isn't seated?
You've heard of tender coils right? There is very little difference between a coil unseating and a tender coil simply maintaining coil alignment under full droop.
I wouldn't mind a coil unseating 8+ inches (for an example), so long as it doesn't pop out. Again... there is no such thing as "too much travel" when it comes to this sport, as long as everything works in harmony.
I would totally agree with you on this, but then I think I would be wrong.
Once its unseated, there's not really enough weight there to give it much traction or steering power, but it can still get hung up in the rocks or catch a diff.
I'd rather lift a tire than have it dangle there uselessly.
