OverlandZJ
NAXJA Member # 101
- Bristol,PA
Guys, need quick answer if possible. In the middle of swapping ball joints on my son's YJ...he has the pre 90 knuckles with the larger nut on lower ball joint. Anyone happen to know the size? IIRC it's 1 3/16'?
Gotta run out and pick up a socket..
Edit: The new balljoint nut size is 1 1/4" or 32mm..but the older nut is just a tad bigger.
