TheMule1
- Brownsville, Texas
so i just finished everything on the install on my ford 8.8, aussie locker, 4.88 yukons, after driving it around the block it started to create a low pitch wine over 10mph-30mph (i didn't go over 30mph), put i could only hear this wine while i was pressing on the gas, if i let the peddle go the noise went away.. NOW i did notice when i installed the ford 8.8 yoke on the drive-shaft, that 1 of the stick bearings from the u-joint came out.. at the time i didn't think anything of it, but now i'm thinking that's the problem. I'm gonna be changing out the u-joint tomorrow but just in case that's not the problem what would you think it is?? maybe a bad outer bearing?? i didn't change them when i installed the axle because they seemed fine.
