- Bakersfield, CA
Just moving this back to the top, to go along with the other long arm discussion......FWIW.
Goatman said:Just moving this back to the top, to go along with the other long arm discussion......FWIW.
Beezil said:oh goatie, you are always lookin out for the long-armers.....what a guy!
jnackos said:Just when I have my mind made up to get a LA kit (I was going to order it tomorrow) you guys have to sink my dreams!
Clearance was a concern I had with the LA kits - I have been looking at the Full Traction kit. The mid-length arms look like a nice compromise and I really like the way you moved the axle mounting points up so they don't get whacked.
However, I am not a welder or a fabricator - I would like to learn, but time doesn't allow. So now that you have torpedoed my long and hard earned decision (I've been lurking other XJ boards for months - I like this one much more), what is a good "bolt on" compromise? I guess it wouldn't have to be bolt on, but I don't think I will be able to get someone else to do all of the fab work for the ~$2k I would pay for the LA kit. I would like to have a good compromise between having a very capable trail rig, but also be able to use it as a DD. Any suggestions?
pfogle said:Maybe we can get some LA people to post a few pics of their setups, and actually see just how much clearance they're losing compared to Richards.
Nay said:Long arms have a huge clearance loss compared to Goatman's setup. But unless you are going to build a D44 front end from scratch, you aren't going to have his setup.
There's no reason one cannot copy Goatman's mid arm on a 30, which is exactly what I did. The only thing I did different was to retain 2 uppers, therefor I made mine longer than Richard's as I wanted them the exact same length as my lowers.
I don't think the guys with long arms tucked inside the frame have any real clearance issues, but IMO mounting them below the frame is a huge step back from stock short arms, & drop brackets don't belong anywhere on the trail.
Paul
andyr354 said:Goatman:
Do you have an upper arm on the drivers side? I can't spot one in the pics.
Goatman said:Besides, everyone of us has a thing or two on our rig that friends can rag on us about, so have fun and don't worry about it.
Beezil said:yeah, its a real bitch when this happens at mickeys hottub, and you look out your window right before your fifth attempt, and goat is sitting there grinnin his silly ass off.
FarmerMatt said:He tends to do that a lot. He doesn't like it when you do it back at him though.
FarmerMatt said:Now that's not quite fare. I was hung on the cross member, not the arms or mounts,
Matt
