wavingpine11
- Central PA
So far I've altered my plan to save for 4.88s and selectables front/rear.
For right now, I'll pull the front d/s and just work out some of the other bugs until I can get the cash for the major surgery. I've heard the carriers are weak on both the 30 and 8.8, so replacing them with full carrier lockers seems to be wise. I'd rather repair the weak u-joints on the trail than have to get dragged because of an exploded diff. I don't think w/33s that would ever happen, but I'm not interested in ever telling a story like that...
In any case, I'm still interested in hearing about lived experiences with FT 4wd and a locked front.
Thanks to everyone so far!
I applaud the choice of selectables front and rear. You have the best of all worlds there! I'm a couple years into these u-joints (front and rear shafts) and they were all super tight with no play when I went over them last night.
I have an 8.8 sitting in the garage that I'm going to put an OX in if I ever have the money for it. I've been waiting on it because I'm also thinking about upping the lift height and going with 35's, but it's like knocking over dominoes where now I'm investing in new coils, leafs, shocks, the not-inexpensive locker setup, gears, and whatever else rears its head in association with ensuring good handling and braking. What I didn't want to do was weld on the spring perches for the current drive shaft angle and then have to cut them off and redo that for a different lift height. Looking back on the build history of my projects, it makes sense to recommend that if you can afford to do everything the way you would ultimately want it the first time around, you should. It will save you many hours of unwrenching and rewrenching, and also cost less in the long run since you aren't rebuying parts to replace other parts you already bought to modify your rig.
