fatwreck
- ottawa, il
OneTonXJ said:Except that HP housings are getting a little more pricey and a little bit harder to come by. Also, you don't have to cut down the waggy 44's. This is nice for the folks that don't have the ability or courage to do this sort of work.
That is exactly why I went with the LP waggy 44 option. Now that I have more experience, I'm not sure if I would have done the same thing again or not. I do know that I probably would have taken the time to cut the knuckles, turn, and reweld them for a better pinion angle....but it doesn't really matter with my 6" lift and the locking hubs.
Mine ended up being as close to bolt in as possible. I built it up using the measurements from the 30 to locate the control arm mounts, trackbar mount, and coil buckets. I then took the 30 out....sold it....and put the 44 in. My friends and I were able to bolt the 44 up in a little over and hour. Very cool.
I have more stuff about it written on my site here:
http://www.projectxj.com/mods/dana44.htm
