DeathValleyPaul
- Los Angeles Area
JKS Quicker Disconnects Model 2002 for 84-01 Jeep Cherokee XJ. (Also fits 86-92MJ, and fits 93-98 ZJ) This is for stock to 2 inch lifts. I used them with a 3" lift, and had no problems.
For more than 3” lift:
As I increased my lift from 3” to 6" I added longer brackets. (With long arms you have to use extended mounts to keep the sway bar from hitting inner tie rod end).
Now I trailer my Jeep so I don’t bother with them.
Quick and Easy describes using them. You don’t have to level your Jeep to use them either like the other imitators. Instructions for mounting included. They have zerk fittings so they can be greased.
You may or may not have to enlarge two existing holes on your XJ to use these.
$100 firm + $10.95 postage to lower 48 states. I will ship same day. Paypal OK.::
New pin bushings and new pins included.
For pictures or info, include your e-mail address in the PM.
