Iron Rock HD Tie Rod and Tie Rod Ends $50
CaliGold
Iron Rock HD TIe Rod. No scrapes, good shape. 1.25” solid steel. Here’s a link to the product page:
http://www.ironrockoffroad.com/Merc...=IROR&Product_Code=IR-SHDTR&Category_Code=XST
Also comes with stock size tie rod ends with less than 15K miles, but boots not included. This replaces your stock tie rod assembly.
Inner TRE is tight and smooth, but the outer TRE is tight but binds in some positions and it should probably be replaced. I did not use a pickle fork to remove this, so there’s no damage.
Use this with your stock drag link and upgrade that stock twig of a tie rod.
$50
pick up in Hawthorne 90250 or SFV 91335
PM if interested.
Still available. I'll post when sold. PM me if interested.
So, does this actually use stock TRE's? Or something like 3/4 ton TRE's, with larger threads and stock taper?
It uses stock size TRE's.
Sorry can't ship.
Sale pending with other member.
