Look, I understand 90% of it. Its just things like what the S is S159 mean switch?, splice? I just dont see anything on there going to reverse lights turning on that's all. And i dont see a blue wire on there anywhere. Its blue with a black stripe in it. All im seeing from the Transmission Range Sensor (aka NSS) when in reverse is BR/LG (brown lightgreen?) I dont have any brown or light green thats all so calm down.McQue said:Listen, if you can't read and understand the schematic I posted, you shouldn't be messing with this stuff....you are going to fry something, or even worse, get hurt. I am not trying to be a smart mouth here...just trying to give you some good advice. Good luck with whatever you decide. Be careful!
Ive got the whole setup using momentary switches, it doesnt take as long as you think once you get the right idea with it. The reverse has to be mounted perpendicular to the axis of the shifter so it was a little more of a pita than drive and park due to the "pressure angle" or "transmission angle" however you want to term it.Pelican said:What did you do to get the back-up lights to work?
