wingtime
- Clearwater, FL
While working on the XJ last night I went to start it. The key wouldn't budge. So I pushed the gear shifter forward to make sure it was in park all the way. Still stuck. Tried wiggling the steering wheel thinking the lock was bound up. Nothing. Popped the gear shifter cover off and wiggled the safety interconnect cables. Still stuck.
I endeded up pulling the steering wheel, and the turnsignal assembly. After probing around and pushing "tabs and Buttons" in the column the key turned.
How do I get the key tumbler out of the steering column to replace it? When we bought the XJ it was from an impound. The original key tumbler had been removed since they didn't have a key to it. They had a key tumbler that had some tabs ground off of it that you could stick in and out of the column and start the jeep with out a key. I had sitting in the bottom of my tool box a new key tumbler that someone had given me for my CJ. I stuck that in the coloumn and it just snapped in place and has been working fine untill now. I think that my be the problem since it may not be the right tumbler for the XJ. Is there a special tool to remove it?
Has anyone had a similer problem? and if so how did you fix it?
Thanks!
Thanks!
