Matthew Currie
NAXJA Member #760
- Vermont, land of big clay
Putting that thing back is a little harder than getting it off. Two hints: first make sure that you have either a magnetic insert in your socket, or some other means (even a little piece of paper jammed in it, putty, chewing gum, or whatever) to keep the bolt in the socket; second, make sure you use the little plastic dust shield that should have come with the new CPS. It snaps into the bell housing, and when installed, it will hold the CPS more or less in place while you use your other three hands to get the first bolt in.
