old_man
- Loveland, Colorado
If it locked up, I would be worried about a busted rod.
Sometimes I hate it when I am right. :doh:
The Crane cam runs about $150, but that's for a short rod setup...which won't break my bank by itself. I haven't done much research into the long rod setup beyond the fact that I'll need custom pistons. I've never had any work done at a machine shop before, so that part of the budget is a bit over my head at the moment, but I definitely don't intend on half-assing a stroker build if I go that route. Would a donor motor, given it's in good condition, require machine work at any level, or is that more for rebuilding and/or building a modified engine?
What I'm gathering is, the most complete remedy would be a donor 4.0, and redo the gaskets and seals while it's out. The next step up would be a rebuild of a donor (I think this would only be an option if I found something really cheap that actually needed the work?), then a stroker build, then a crate motor, (too expensive, not even in my ballpark of options).
Just got off the phone with a buddy of mine who runs an offroad shop. He told me my money is best spent on another 4.0 that I clean up and after plenty of research and hearing the comments on here, I'm tending to agree with that. A modified engine that'll cost 3-4x as much for a few extra hp and torque numbers while tempting, just doesn't make sense unless I'm itching to burn cash and have tons of time on my hands. I'd rather get her back on the road and continue exploring this spring and summer, as opposed to having her sit until I save up and gather parts. It just makes more sense that way. Thanks for the help and the welcoming words everyone, this board is awesome.
If you have a 98, your castings are specific to 97/98. You should be able to run any motor from 91-98, though, bolt in but different casting numbers. While its out get an intake manifold from a 99 (also its power steering pump/bracket).
While its out, I'd do the rear main seal, replace the harmonic balancer, valve cover and oil pan gaskets. If you want to pony up for a Melling or OEM oil pump, do that as well, but don't buy a cheap one.
Water pump and thermostat, hoses, belts.
