RichP
- Effort, Pa
PGT FTW said:how long for an experienced shadetree to do this? I got a quote for $800 on my '01 XJ. I need to make a run to NJ sometime in the next week and don't want to put miles on it before doing the front bearings.
Totally dependent on how hard the hubs come off, some of them can be real bastards. Snap on has a neat socket set that goes on an air chisel, sockets that fit over the bolts in the back and literally drive the hub out. A zzzzzzt on one, zzzzzzzzzzt on two, etc and out it comes.
As for reassembly I stopped using that silver anti seize after I found out the copper based stuff is much better, The aluminum stuff an react with steel form almost an epoxy. I use Barnes hi temp no 21961 now. Work the knuckle surfaces over with some 3m pads first, coat the hub and put her in. Now is also a good time to do the universals.
