HarryTasker
- Portland, OR
Here is a little back ground. I a own a '96 for Ranger not an Xj. I have no fabrication skills, no tools, no place to do any work on my vehicle for more than a couple of hours and this truck is my daily driver and only vehicle. All work will be done at a professional shop I have used in the past.
So on to why I am posting. I have a HP Dana 30 for my front axle that is mounted using Rusty's Off-road long arm kit. Tires are 33x10.5 BFG KM2. I am going to re-gear for 4.10 from the stock 3.73. The 4.10 will match the 8.8 axle I am having installed. I am looking more for re-assurance that my reaseach thus far is correct or any warnings against it.
So here is what I have found.
1. There are no factory replacement Dana 44's available for the XJ. I can have one built, but I will have to go to a company like dynatrac and the expense of a complete axle will run in the area of $5000.
2. Since I am having the 4.10 gears installed I also looked at what else cold be replaced with limited labor. Right now the center disco is welded with the motor removed and a cover plate in place. I am under the assumption that since I have to have the axle dissasembled to regear I might as well replace the inner passanger side shaft with a one piece.
3. I also read that should one of the axle shafts break while driving the wheel can actually come off the axle entirely. The resolution for this is the Randy's R&P hub conversion kit formerly known as the warn hub conversion kit which will also provide new outer shafts.
4. Since I am already replacing the passanger side inner shaft and both outer shafts why not replace the drivers side inner as well.
5. I called Randy's and they quoted me about $1800 for the hub conversion (27 spline), new inner shafts, the 4.10 gears, and a master install kit. I believe all are Yukon brand and the shafts are 4340 Chrome-Moly.
So to me it looks like I can beef up the HP dana30 for about $2000 in parts and about $1000 (high estimate) in labor. Or buy a hp Dana 44 and spend about $5-6,000 in parts and then a couple hundred more in labor.
Any thoughts or constructive critsism?
