joe_peters
- Grants Pass, OryGun
There is this ANNOYING button that has "magically" appeared on my window and I want it disabled or gone.
Any ideas?
Any ideas?
userCP -> edit options -> "members chat" disable.
hope this helps.
hope this helps.
Pull out the chat vacuum tube. That should do the trick.
XCM's fix should make it impossible for your computer to connect to the envolve chat program's server, that would be a permanent fix (provided you are on a PC, I don't know if a MAC has a hosts file :dunno
# Copyright (c) 1993-2006 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
::1 localhost
200.200.200.200 *.envolve.com
Unless that's not it's home server.
