- Rainy side of Washington
ok, you got me there. If I had a chance to see KMFDM or Rammstein in concert in the US, I'd probably pay dearly.
Did I miss the Dyno numbers, I have been looking forward to them .
Bryson...i decide to go for AEM FIC but i need some help to install and tune...you have some programm or setup ready?
please give me a hand with my home project...
Thanks
JP
How does the new power compare to a supercharged 4.0? I drive a Subaru WRX, so I can appreciate what a turbo can do for my little 2.0 boxer engine. I'm curious to see the dyno numbers. Did you do a cost analysis between setting it up with a turbo versus setting it up with a supercharger?
X2How does the new power compare to a supercharged 4.0? I drive a Subaru WRX, so I can appreciate what a turbo can do for my little 2.0 boxer engine. I'm curious to see the dyno numbers. Did you do a cost analysis between setting it up with a turbo versus setting it up with a supercharger?
I'm in the process of a similar manifold based turbo build.I'm fabbing the downpipe and wastegate pipes right now.
I havea question for Bryson.I noticed that the wastgate discharge enters downpipe between two o2 sensor locations. I have a 2000XJ, so I have one more pre cat O2 two install. Is their a need to have wastegate gasses read by the narrow band O2's??
I would like to run a seperate wastegate dumpipe since its easier to fab up and install.This probably wont hAPPEN. I want to maintain A efficient wastgate intergation to downpipe. Problem is were I want to run the wastegate pipe into the downpipe the O2's will be opposite the wastgate gasses. I'm afraid of turbulance screwing up o2 reading.
I'm also curious as to the best location(distance from turbine discharge) for Wideband sensor location??
Bryson, this stuff looks awesome. The only question I have is why did you choose to use a blow off valve vs. a diverter valve? It seems that a BOV (while it sounds really cool) just releases useful compressed intake air.
