Some updates!
For the past 6 months or so I've been nursing a slipping trans. The stock trans seemed to hold up great over the past couple years until I noticed a slight slip one day on the 1st to 2nd shift. After that it was slipping every time I hit boost. After talking to Chad at Fringe Development, I decided to try out his built trans that he documented here on naxja. Along with the trans I had him build me one of his valve bodies along with the full transgo shift kit. The trans was an OBD1 however, so I did have to do some fab work to make the swap into my 99 which I'll outline in the pictures below. Overall it was pretty straight forward, and the trans has been working great. No slippage and the shifts are nice and firm. 1st gear lock works great as well, and should be fantastic on the trail.
While I was at it, I added a Transdapt filter setup to the cooler circuit mainly for the piece of mind. The tricky part however was trying to find a location for it. With all the turbo stuff and hidden winch setup, there was little to no room in the engine bay so I was forced to go the other direction and place it back near the transfer case. In it's current position it's pretty vulnerable to rocks, but I have a belly skid in the works. In prep for the belly skid, I also clocked up the transfer case a good ~10degs or so using IRO's drill jig. The shift linkage is now even more crap, so I'll be getting novak's linkage kit here soon. I did also have to cut off the casting "ears" of the case to clear the floor pan.
As for the Dyno, Marty pretty much summed up the issues. One solution I've looked into is the radesigns shifter, but it appears the 98's and up will end up getting a CEL. I may end up just fabbing some simple switches to hold 2nd and 3rd gear just for dyno use.
My 99 had this speed sensor in the front part of the case. The earlier trans unfortunately did not, which meant I had to pull the oil pump and OD planetary to be able to safely drill the case. The case does have tapped threads however for the sensor, so I just needed to drill the through hole. I also needed to swap the clutch pack housing as the late model has a tone ring welded to the outside. This was simple enough, but did require the swapping of the new clutch pack.
The tail shaft speed sensor is different as well. The early model uses a two tabbed tone ring, while the late model uses a four tabbed tone ring with a circlip. Because of this, the early model output shaft doesn't have a groove for the circlip. Luckily they both use the same woodruff key and are the same diameter, so I simply drilled and tapped the late model tone ring for a set screw to hold it in place.
Early:
Late:
Tone ring installed:
The rest of the swap pics:
lines tucked nice along the inner frame rail
