joe_peters
- Grants Pass, OryGun
If a filter has double the capacity of a Fram filter, will this require more oil in the oil pan?
Stock filter: 1/2 quart; vertical or horizontal mounting.
Wix 51515 or equivalent: 1 quart; vertical or horizontal mounting.
Wix 51773 or equivalent: 2 quarts; vertical mounting ONLY.
Note: the 51773 is the 51515 on steroids, but there is a downside--the 51515 filters at 21 microns, the 51773 is at 30 microns. There is no free lunch!
Other note: the 51515 and 51773 are SAE filters, and only fit 91+ 4.0 UNLESS you have modified the earlier OFA to accept SAE threaded filters, Chryco part number 53007563AB, or you have installed a 91+ OFA.
