r33pwrd
- Sammamish WA USA
depends on the axle you put them on and a majillion other things, unfortunately.
I'm running 33x11.5 retread ATs (actually a 285/75r16, measuring 33x11.4" with 8.8" tread width) on 16x8 crager V5s with 4" of backspacing (0" offset) and they fit fine. A bit of LCA rubbing but I could care less, I clear the leafsprings and have decent turning radius that's what I care about.
On the other hand, my bald 32x12.5 BFG MTs on stock 15x7 jeep rims with 5.25" of backspacing were within 1/8" of an inch of ripping the sidewalls open on the leaf spring clamps. They were so close that they left a clean ring on the sidewall where there was less road grime.
Depends on your backspacing/offset and wheel width. Crunch some numbers and see what you come up with.
If you think you might end up rocking a Ford 8.8 rearend at any point, knock the backspacing down a bit when you order your rims. That axle is about 5/8" narrower per side iirc, personally I subtracted an inch as I was planning on running one in that rig at that point.
Using the wheel width and the backspacing you can calculate the fraction of the tire that will be "behind" the wheel mounting surface, then take the section width of the tire you're putting on it (13.5) and figure out how many inches from the wheel mounting surface the inner sidewall will be. At that point you can measure (or run the same calculations for your existing tires and rims, then check clearance on them) and figure out if you're in the clear or not.
cool thanks! should these with a 15x8 wheel 4" backspace 33 - 13.5 tire fit OK?
this kind of confused me /\
i know the pictures can be decieving but did you say that the wheels were 15x8? because in the pictures those tires do not appear to bulge out much for being 5.5in wider than the wheel
