4x4 XJ
- Carson, CA
Hey all, I need some help and advise with my lift project... this is a 3" lift from rocky road outfitters. This might be simple questions to many of you.. but this is my first lift ever.
1) the pin on the lower part of the lift block is two wide for the hole where it needs to sit...do I grind the oin to make it of make the hole bigger..
2) how do I change the bolt in the middle of the spring pack and what size is it..
Thank you all in advance for any help..
