Sidewinder CC
- Canton, Michigan
Update:
Got the Jeep into the shop and started testing.
I have no spark and no fuel, although the fuel rail is pressurized.
Fuses are good and power at ASD and fuel pump relay checked with test light (ruling out ignition switch).
I have NO 5 volt reference on the shared signal line.
I've pulled the IAC, MAP, TPS, VSS, EVAP purge solenoid, low pressure AC cut switch, cam position sensor, crank position sensor and NO 5 volts.....just trace voltage.
I have battery voltage and a good ground to the PCM. The PCM still gets warm to the touch near connector A anytime the battery is connected.
So, it would seem to me that I have a bad PCM here. I don't want to replace it however just to have it blow again because I have a short somewhere. Should I do additional testing on all the sensors to make sure I don't have a short somewhere that could render a 2nd PCM a paperweight.
I put the door lock fuse back in and they cycled once and stopped. I hit the switch and they all worked. I removed the fuse again. So, my theory as it sits goes 2 ways.....
1. I had a short to power in the door lock circuit which drug down the battery. When I jumped it, either do to age just dumb luck the PCM fried.
2. The PCM shorted internally initially, dragging the battery down confusing the door lock module with questionable voltage.
Thoughts?
What do you mean "Shared Signal Line"?
You shouldn't have a 5 volt reference on a shared signal circuit.
Look for 5 volts at least one sensor at the pin cavity with the Orange wire. The 5 volt reference originates at pin A17 of PCM connector C1 (Black) then is spliced, like a spider web, to all other sensors using 5 volts.
