lawsoncl
- North Idaho
purvisdotcom said:From your PM (hope you don't mind, thought I'd throw this out in the public area too).
I have a BA10 that I am also going to swap for an aw4, I was wondering do you have to add in the auto cable to the throttle. what all modifications need to be done?
Yes you need to add the throttle-tranny cable as it controls the hydraulic pressure and shift firmness. I swapped the plate on the side of the tranny where the throttle and tranny cables attach since the original didn't have the stud for the tranny cable.
As side from ensuring that the spline count is right for your xfer case, you'll need to swap over a lot of other misc stuff. From my short memory you'll need: tranny cable, throttle plate with extra stud, and the cable bracket that attaches to the side of the throttle body; TCU and it's wiring harness which you'll need to dig into the mainharness to splice about 7 wires in; NSS, shifter, bezel and the plate it bolts to; xfer case shifter bracket and linkage; possibly driveshafts if the length changes too much; extra switch on brake pedal that hooks to the TCU (I just added a relay to the existing switch); dual output TPS sensor.
I also ran into a complication that I was trying to use an 89 TCU with a 99 AW4 as the sensors changed a bit in 997/98. Not being able to find a 99 TCU, I built an adapter to convert the sensor signal.
