Blaine B.
- Northwest Indiana
Even alot of short driving.....I wouldn't except you to get less than 10, especially with a newer Jeep like that.
97 Green Machine said:I put new plugs, wires, cap, rotor, air filter, thermostat, oil and filter, and did a coolant flush less than 1,000 miles ago. The upstream o2 sensor has about 5,000 miles on it.
I can. He described his trips as being "a couple of miles or less". Back when I first got my XJ and didn't know squat about cars my distance to school was roughly a mile to MAYBE a mile and a half, and I didn't really let the engine warm up before I left my driveway (parked outside). So it would just barely hit 210 before I got to school and cut it off for 7 hours, only to do the same again going home. This resulted (before the tune up and me getting edumacated on cars) in a shotty 9mpg average for me. After gaining knowledge on how that's MURDER for an engine, I began to drive around the block...that and i began going to grab breakfast before school and hitting the drive through rather than getting out. This resulted in my trips going from 1-1.5 miles to about 5 or so, and untill recently I never had any problems out of mine.Blaine B. said:Even alot of short driving.....I wouldn't except you to get less than 10, especially with a newer Jeep like that.
Blaine B. said:What was the maximum MPG you got after driving around for extended periods?
I do basically the same as you did in the winter and still get above 11....and then when I don't, it increases. Summer high for city driving was 14.
Blaine B. said:I've run seafoam through the tank and crank, and recently did the marvel treatment in the tank and crank as well.....
EliasJ123 said:So, what kind of results did you get?? Performance?? Better MPG?? Nothing, except a false sense of satisfaction???
Nope, my XJ runs better than any other vehicle I've ever owned. The exhaust smells a little rich when it's cold, but not after it warms up.casm said:Are you noticing anything else like backfiring, stumbling, or bogging down? Does the exhaust smell like unburnt fuel at all?
When I drive without stopping on the freeway at about 70 MPH it averages around 20 MPG. As soon as I do any in town driving though, the gas mileage plummets even when the engine is at full operating temperature.casm said:Try this: get it out on the freeway with a full tank of fresh gas, zero the trip meter, and drive 30 minutes one direction and 30 minutes back. Refill the tank, work out your fuel economy from there, and report back. This should give it enough time to run good and warm at a steady speed, which will also give some indication of how far out of whack it is or is not - and whether or not all the short trips are in fact the culprit.
Both of those are factory stock. I'll have to try replacing them if some other things don't fix the problem.casm said:There are two things I don't see listed here: a new ignition coil, and a new coolant temperature sensor. I'm not saying that you shouldn't try the recommendations that've already been made first, but what's the condition of these two items? Especially interested to see if it's running rich based on how the exhaust smells.
I park outside and usually let it warm up for two or three minutes before I take off. It's never fully warmed up before I start driving. I'll try letting it warm up more to see if that makes a difference.99XJSPORT06 said:Getting back on topic here, try letting it warm up some before you get in and blast off, especially if you don't have a garage to park it in. Even so much as 5 minutes can make a big difference.
What is the fuel pressure supposed to be on an XJ at idle? I have a fuel pressure tester, so I'll have to check that. Also, how much vacuum should the engine pull at idle?autocrossxj said:On my friends 96 suburban the fuel pressure regulator went out on a vacation, mileage went from 17 hwy to about 5.. but he said it still drove the same when it was gettin bad mileage. after it was replaced the mileage returned to normal
casm said:A lot has been written here about which plugs to use. Without rehashing that argument, I would recommend ditching the Champions and going to either the stock-recommendation NGKs or a single-electrode platinum. I used the Champion truck plugs for probably close to a year in my 2000 and had approximately a 10% decrease in fuel economy; swapped them out and things went back to where they should've been. .
