- Coshocton, OH
dmillion said:Get a VOM and test the voltage at the headlight plug with the engine idling. If it is above 12.5 volts then a harness upgrade will not make any noticeable difference for you. On my '01 the voltage at the headlight was 12.9 volts so spending time and money on a harness would be pointless.
This doesn't mean that ALL 2001's will be the same. I've heard of some that measured less that 12.0 volts at the headlight plug. But a tester is only, like, $10 so it is dumb not to get one and test your own connections before spending the time and money on a harness upgrade.
Remember you need to have the headlight connected when you do this. You won't get an accurate voltage reading without the current draw of the light.
Also the working voltage of a operating vehicles charging system is closer to 14v (my 2000 holds 13.8v when running without any acc. on)than 12v.
