Soooooo I am an idiot.
I hooked the ground jumper to the 5v sensor wire at the O2........
corrected it and we are back to square one. no more super surging idle but, we still have a low-er idle and a miss.
so what I did was force open loop. now whats strange is that when it was like that after fully warm it idled very smooth just very low.
that leads me to think its a sensor thats causing atleast part of my issue.
I suspect Knock even though its not hooked up I think its picking up interference. So I think I will cut the Knock wire at the ecu and wrap it in foil and tape.
either way that should eliminate it as a possible issue.
I am also going to check the timing with a timing light and see if I can learn anything. maybe i indexed wrong.
then i am going to double check the tps adjustment. i have checked it a thousand times but i keep reading i should adjust from the transmission side and get 4.82 volts.
