Things keep getting weirder and weirder...
I decided to pull the relays back up and see if I could see anything obvious. which I did, but thats not the issue, I dont think it is anyways.
this is the diagram showing what relay is what. there is another that shows the ac and o2 relays switched but i tested them and this shows the ac relay in the correct spot.
here is a pic of my relays.
the relay that is missing is the one that when pulled stopped supplying voltage to the O2 heater. exactly 5v. key on not running.
as you can see there is a bit of insulation damage to the large wire. in the middle
according to that diagram, that would be the power latch relay.
also the far left relay the one the diagram shows as the O2 heater only gets 10.5v out of 12.3 the other relays are getting 11.6-12
but to me that looks like a fuel pump relay as it has the largest wires.
I am so confused right now. :banghead:
I am reviewing the FSM now
