Ok I am wanting to know if it will fit. Has anyone tried this. I really would like the split folding option for easier access to our third row seat. Thanks for any info on this.
IIRC you'll have to manufacture whole set of mounts for it as it mounts differently then the stock back seat. ALso I'm not 100% sure but I think the width might be an issue as it fits slightly differently in relation to the rear wheel well. You might start off with a tape measure and check things out before you get started on it.
I thought of this a while back too. It's POSSIBLE. But will take a lot of work. The GC seats are slightly wider (about 2 inches) and the mounting points (to the floor) are radically different.
Possible, but difficult as I was best able to determine.
What third row seat? If you have custom installed a third row seat in the cargo area, you could just do aftermarket buckets with five point harnesses in the second row. That gives a lot more space than a bench, although mounting points aren't so easy.
