Why do you say this? I've heard that header wrapping can cause warpage of the header and mounting flange.selarep said:.... Just get an exhaust wrap for it.
OEM tube on mine. May replace it at some point.SteveT said:What are you APN guys using for a downtube? I like the price of the APN, but I also don't mind buying quality.
I'm also looking at Kevin's system ( http://www.kevinsjeepparts.com/exhaust.html ), because my cat and muffler are original '96 parts, and in need of replacement.
It's seems that the original downtube is a huge source of restriction.
Steve
Link doesn't go to any products. It saysSteveT said:OK, now I'm thinking economically. Any one have an opinion on this muffler?
http://store.summitracing.com/compare.asp?N=700+400238+320931+4294791975+115&autoview=sku
89Daytona said:Why do you say this? I've heard that header wrapping can cause warpage of the header and mounting flange.
89Daytona said:Wrapping a header keeps the heat in it, so how could that not make the header be hotter than an unwrapped exhaust. More heat cause an increase in metal expansion, which can lead to warping. Header warpage after wrapping might just depend on the type of application and header material and thickness used (more likely to warp if its a cast header).
http://www.centuryperformance.com/heatwraps.asp
http://forums.mg-rover.org/showthread.php?p=2046651
93XJLI said:Just an FYI, those skid plate FLowmasters weigh almost 100 lbs...
Care to post a site that can back that claim up?93XJLI said:Just an FYI, those skid plate FLowmasters weigh almost 100 lbs...
cjben said:if you are talking about a regular flowmaster for a jeep,i have one in my garage,and i gaurantee it doesn't weigh 100 pounds. i doubt it weighs 25 pounds.
