Due to a job lay-off, I may need to sell my '92 XJ. I've never been a fan of these "gauging interest" posts, but I'm a little on the fence about selling it. It may come to the point when I have no choice but to sell, so I'm hoping this will provide some good feedback and I can adjust accordingly.
It needs work, so this might make a nice project for anyone wanting to get into the off-road sport on the cheap. It's past due for registration (Aug) and I haven't had the time, energy or funds to fix things.
Leading particulars
'92 Laredo (green)
Auto
Power windows & door locks (typical sticky door locks and slow moving windows)
Factory roof rack
Sony CD player
6" RE lift (RE1462 leaf packs and 4.5" coils)
ACOS
Boomerang shackles (JKS, IIRC)
RE adjustable control arms, top and bottom
RE control arm drop kit
Homemade sway bar discos
OEM gas tank and TC skids
4.56 gears
Open front & rear
SYE & custom drive shaft, both from Tom Wood
ZJ drag link and tie rod
RE adjustable track bar (w/ extended TRE) and mount
Late model 8.25 axle with 29-spline shafts
32" BFG A/T tires
Alloy rims (one is an odd ball)
JKS front shock post eliminators (not installed)
Full size spare
A few extra parts (OEM tranny mount, aftermarket engine mounts, later model steering dual diaphram booster, and probably a few other things)
The ugly
Approaching 200K miles
Rear main seal leak
Valve cover leak
AC doen't blow cold; had it converted to Freeze 12, but never worked right
Exhaust manifold crack
Two tires need replacement soon
Needs new shocks and steering stab
Paint cancer
Factory tint bubbling
Has driveline vibs
All fluids due for a change
Has intermittent engine power issue. I replaced all sensors, cat, and had a handful of shops look at it. No codes. Maybe related to exhaust manifold or something lodged in downpipe? Dunno, but was going to inspect whenever I got around to replacing exhaust manifold.
I'm thinking $1600 or very near offer.
Leading particulars
'92 Laredo (green)
Auto
Factory roof rack
Sony CD player
ACOS
4.56 gears
Open front & rear
32" BFG A/T tires
Full size spare
The ugly
Rear main seal leak
Valve cover leak
Paint cancer
Has driveline vibs
