This guy is NOT running mj leafs, Colin was, what part of that does you nots understands.I think he's broke like 4 or 5 main leafs.
you're going to want to tack weld your jam nuts on your lca joints at a bare minimum. That line's location makes me nervous, especially when looking at the condition of my lca's.
The axle end of my control arm is a fixed poly bushing/sleeve and wont rotate. If it proves to be a problem then it would be very easy to move the line. though Im not sure where...
So I am having trouble with my trans cross member. I only made this one so I could get it out of the shop. I was planning on a flat belly skid plate, but the trans mount hangs down way to far... Does any body know of a short chevy trans mount? I cant raise it anymore because the bell housing will contact the firewall. Maybe shorter engine mounts? If I dropped the engine 1 inch then I could raise the trans another inch... Thoughts?
And yes, the front driveshaft angle is steep. 40 degrees at full droop. Angle is great at ride height but the 17 inch travel Bilsteins really droop. I am putting together a hi angle shaft with a custom 208 flange. Angle at pinion is fine though.
That reminds me of a time that a guy I know welded up some spiders very similar to that and then couldn't figure out how to get it in the carrier. So, he cut the carrier in half, installed the spiders (Welded together) and then welded the carrier back together, set the gears up.
Needless to say, it didn't last very long.
gunna shave it?
