FS: TNT trackbar bracket
ruggedjeep
Sherman Oaks
Hole is drilled out to accepty a 5/8 bolt, i ran it with the RE1600 trackbar. You could weld spacers to make the hole smaller and run a standard 10mm bolt.
compared to stock
drilled out, larger hole.
brand new this is $80+
yours for $40
:chug:
Too late, oh well. What are you running now? I assume you were using this bracket with a 5/8 heim spaced to 2" wide.
-Mike
