- Rainy side of Washington
If you feel like it you can pull the axle housing out of the vehicle (or drop it down enough to remove the coil springs) and use a BFH to pound on the inner Cs and bend them outwards a tiny bit. It won't take much to correct your camber.
I did this on an axle that came into my possession with 3+ degrees of camber on each side from a few awesome Dukes of Hazzard jumps by the previous owner, and have run it for something like 25-30 thousand miles now with no adverse tire wear (on two separate sets of tires, both back when it was stock height still and after lifting it and putting my 33s on it.)
I wouldn't bother though. You're close enough to spec that it shouldn't really matter that much unless it has some screwy handling characteristics.
