mk153smaw
- Fort Lee, Va
I love threads like this. It helps me to make my tool kit smaller. I currently bring a whole shop worth of tools because I always over prepare like a total noob! I need to make trail tools
Some people think anti-seize is the devil, others use it everywhere.Clean-RC said:I would never use loctite in this application.. And yes I do torque the axle nut, that is why you should never need a cotter pin.. I recommend antiseeze due to the large number of rigs that have the threads all rusted and what not.. But I guess you have more years racing than I do...
I am with you, Lock tite the crap out of everything, use a torque wrench and never have to tighten a nut again.RCP Phx said:Anti-seize shouldnt even be used here,unless you trust the cotter key.In my 30+ years of racing lock-tite is the winner.But anyway,most guys have habs that may never come off!
BTW: Do you actually torque the nut to spec when installing,I do!
In his defense, you cannot tell how big it is without anything next to it for a relative reference. At first glance, I thought it looked kind of small too.RCP Phx said:Uhmm,YEAH!! See thread title!
Yeah that's what I was thinking, wasn't expecting such a rude response from him though. I just looked small in the picture and you didn't give any detail on how it worked even though it is kind of obvious. Maybe I just over looked it because of the snot running out my nose, sore throat, fever, and tiredness. But hey I am still at work working hard right.........:cheers:BruceB83 said:In his defense, you cannot tell how big it is without anything next to it for a relative reference. At first glance, I thought it looked kind of small too.
save space in the toolbox? there will always be room for a breaker bar. That and a prybarXJeremy23 said:I remember the first time I tried to break that nut loose I snapped two 1/2" drive breaker bars. Then I went at with a 3/4" drive setup and it broke loose right away. It probebly hadn't been removed for 12+ years at that time. Now I can break it loose with a 1/2" breaker bar but if this tool saves space in the tool box I can see the advantage. But there is other parts that may need replaced/repaired on the trail that may need the 1/2" breaker bar and different sized sockets.
1996cc said:Thats pretty ghetto!The material is not proper and the welds look questionable.
Loctite acts as a lubricant as you tighten down the fastener. After it dries and does what it's designed to do, yes, it no longer acts as a lubricant.Blaine B. said:Anti Seize is a lubricant. Loctite isn't.
Blaine B. said:And when you use a lubricant on bolts isn't it common to reduce the torque by about half?
