x2elite
- Texarkana, AR/TX
TunaSoda said:Do you have any pics of your current setup?
and is your backspacing 4"?
I believe my current wheels have 3.75" backspacing. Here is a photo.
x2elite said:I believe my current wheels have 3.75" backspacing. Here is a photo.
x2elite said:Fully stuffed my Rears will rub a little, but I hardly ever notice. My Fronts don't rub anywhere, but on the control arms at full lock. My tires measure out at 32.6", my lift is a 4.5 inch lift, but if I had to guess I would say I actually got around 5-5.5 inches of lift over stock.
cloudswimmer said:What kind of lift kit is it?Again my Rubicon Express 5.5" Extreme Duty lift kit would not clear 33x12.50 tires on 4" bs rims and stock fenders and flares.Your 4.5" kit must be taller than my 5.5" kit.
Trail-Axe said:When you say; "would not clear," you are talking about when it flexes right? What did you do to gain the added space needed? ...BW flares, raise your stock flares, or something else?
Thanks bro,
Gar
x2elite said:I find that odd..... there are tons of people on here running that kit with 33's and no rubbing issues. I am telling you, I can probably run the 35's on the street without even trimming, as long as I slow down for the big bumps. I run 33's with quite a bit of room to spare.
Trail-Axe said:Slowing down for the speed bumps at the mall is not what we were talking about brother.
JasonCherokee said:Here is a pic of mine at 4.5" of lift, lots of fender trimming and no front bumpstops with 35" swampers.
cloudswimmer said:Ok 35's on 4.5" of lift obviously will give you lower center of gravity, but aren't you also decreasing approach and departure angles, and more prone to hanging up on your rock rails and belly skids?What would be considered a sweet spot lift height for running 35's in the rocks?
