stupidfast
- CT
dude i cant beleive you are finding deals like that. thats rediculos. i need that but im in CT. i would buy that imediatly. but bump steer is easy to understand. think about it like this. if you have a rod connected at one end to something stationary, then you can spin that rod around and it will draw a circle. the same thing is happening with your drag link when the suspension cycles, but ofcourse its not a complete circle. even though it only moves a little bit, its still cycling in an arc on your steering knuckle. that arc is enough to change the distance between the pitman arm and knuckle at compression, so that means the knuckle will be pushed out and turn both wheels to the right. the only way to fix it is to make the drag link and tie rod at the same angle.
the same thing happens with the track bar. when the suspension compresses, the track bar makes the axle move to the right a little. if the drag link is at the same angle as the track bar, then no bump steer will happen.
ive seen some setups where the drag link and tie rod are completely paralell, but i dont know what their track bar set up is, or they must have a triangulated 3 or 4 linked front end. otherwise they would have horrible bump steer as well
