rust bucket xj
- allentown pa
replace that bolt now, re springs are known for shearing/bending the centerpins they use. Use a grade 8 and grind the head to a circle
Do you have anything to back that up? That's the first I recall hearing that one.rust bucket xj said:replace that bolt now, re springs are known for shearing/bending the centerpins they use.
A bunch of guys over on Jeepin have had a problem s-shaping the re pins, and a few have flat out snapped off.Yucca-Man said:Do you have anything to back that up? That's the first I recall hearing that one.
Like this:xjrrrdx said:Now how do you get that in there?
ok....loop said:looks like you need new u-bolts....good luck
I used a vise to do it. Was a lot easier and I didnt bash my hand. I also lubed it up, and it slid right in :laugh3:jeepguy97 said:Put the bushing in the shock, put the bar pin in and pound it.
I'll second that,you'll never miss it.redyouch said:drill out the hole. ditch the rear swaybar too
xjrrrdx said:My wheels are completely stock and I want BFG ATs 31's to be exact, will they rub my LCAs??
