CobraMarty
- PM me any questions
Is the M62 Eaton Supercharger 'big' enough for the Jeep 4.0L?
Right from Eaton's webpage-
"The Eaton Supercharger Model 62 is designed for 2.5L to 4.0L passenger car and light truck engines, but may also be suitable for other engine sizes, depending on total system performance requirements."
A few basic facts about the M62 supercharger
Each revolution of the supercharger puts out 62ci (cubic inches)
Maximum rpm is 14,000
Using the Jeeps stock balancer/pulley which is 6.0" diameter and a 2.25" supercharger pulley you get 2.66:1 pulley step-up ratio.
2.66 x 4850rpm(shift point of AW4) = 12,933 supercharger rpm, well below the 14,000rpm limit.
2.66 x 62ci x 2 (2crank rotations for one engine cycle) = 325ci/1engine cycle.
325ci of s/c air into a 242ci engine = 1.34 = 34% more air than a theoretical 4.0L engine needs.
34% x 14.7 (pounds of 1 atm) = 5.04 pounds
Because the Jeep has such a poor flowing head and minimum cam such that it can't even 'inhale' the full 242ci of air, the % more air is even higher,
So the Eaton M62 Supercharger as pulleyed above will easily provide between 5.5-6 pounds of boost, which is just a little more than the 'theoretical' potential of 5.04 pounds.
