F.N.G.
- New Hampshire
Steering Upgrades
So my power steering went on me while driving the Jeep on the Kancamagus Highway in New Hampshire. With 33x12.5 tires the steering was a little stiff w/o power steering, but not unmanageable. So I was able to drive it back most of the way way. That is, until the bearings give way and the pulley to the power steering pump came off. So, back to the driveway to repair and upgrade...
Problems and Solutions...
Problem #1: Power steering pump.
At this point I decide to upgrade from a stock Cherokee pump to a Grand Cherokee pump. Direct bolt on, with just two minor alterations to the setup.
#1 just need to plug the extra hole in reservoir that is intended to go to the Grand Cherokee Power Steering Cooler.
#2 Swap the 18mm High Pressure Hose fitting from the stock XJ pump to the WJ pump, as the new pump fitting is 22mm and the stock hose wont fit obviously.
Upon further inspection I notice that my steering box has seen better days and is rusting away.
Problem #2: Steering Box
Since the stock steering box is rotted, I decide to upgrade to the Dodge Durango Steering Box. Direct bolt on with no modifications. Upon removing the steering box, I realize that the steering box spacer bracket is cracked and not reusable.
Problem #3: Steer Box Spacer/Bracket
So this is a triangular 3 bolt spacer that sits between the steering box and the sub frame rail on the drivers side. 3 bolts go through the sub frame rail, then through the spacer, into the round steering box. I see this as an upgrade opportunity, but since there is no stock or hd version locally I will have to order one and wait a few days for delivery. Since this is my daily driver, that is an issue. So I simply bought 3 new bolts and a bunch of washers to use as makeshift spacers to get me by until the Heavy Duty Steering Box Bracket arrives a few days later. Ordered one from C-Rok. Delivery is on time, rugged and complete kit, goes in without issue.
Side note: Pitman Arm
Take the pitman arm off before you remove the steering box... lesson learned there.
Side note: Power Steering Pump
Be sure to bleed the power steering fluid through the pump properly, and cycle through your steering before starting your Jeep after the power steering pump install. Otherwise you may burn out your brand new pump.
Side Note: Pulley
Make sure you have a decent pulley installer. Mounting the pulley was a p.i.t.a. as I didn't have a pulley installer and had to rent one from a shop that had seen far better days.
Side Note: Pulley
Power Steering Pump Comparison
Steering Box Comparison
Stock Steering Box Spacer
Temporary Steering Box Spacer
C-Rok Steering Box Spacer
Follow our adventures at Nomad Expeditions
For Wheeling, Overlanding and Travel Pics of the XJ in action
