MGrobe
NAXJA Member #968
- Chicagoland-area, IL
I apologize in advance if this isn't considered an advanced fabrication question.
One of these days or more likely years I'll probably want to add an exoskeleton cage to my XJ as a safety measure for both me and my Jeep. In planning the process in my mind I am curious about a couple of concepts.
Here is background on my Jeep and myself as I know the inclination of some and the type of responses that have been given in the past.
My 98 XJ is in fairly pristine shape with only a couple of minor dents for the 8.5 years of ownership. She still is my daily driver so keeping her intact is still a priority of mine. She doesn’t have an internal cage and really won’t ever have a full internal cage. I may entertain something in the C pillar area but beyond that isn’t likely.
The reason I won’t be installing a full internal cage is due to my physical disability. I have been disabled for 2/3’s of my life and counting now due to severe arthritis which has fused a number of my joints and puts a limit on the amount of lift height of my XJ. Anything higher than my current 4.5”/33” tire and I won’t be able to get into it, especially in the winter when the footing is unpredictably worse. A B pillar support might work if it doesn’t contain any cross-bracing, which makes it questionable for the value of support it would still offer. Without a mock-up I still worry that it would be to intrusive as well.
Back to off-road, my health impairs my ability to arbitrarily attack any ultra-hardcore trail. I have to think about what I am getting myself into prior to entering a trail and sometimes caution is a necessary evil. Reason being is if I roll my Jeep, chances are I will be stuck in the seat in the same position until my jeep can be righted. This can be an agonizing amount of time for someone like me.
Ultimately I want an exoskeleton that can hopefully protect me and keep my XJ in reasonable shape in an unforeseen rollover. Obviously I come first in terms of safety, but I would hope that whatever I build would do whatever it can to spare my jeep from becoming a topless off-road vehicle.
Sorry for the crazy long background and here are finally my two simple questions.
In designing the cage, would it be better to tie the cage in as much as possible to the XJ’s structure their by adding to the rigidity of the uniframe. Or keep it free floating as possible so that the tubing bends and absorbs impact that hopefully won’t be transmitted to the jeep. I realize the answers may vary depending on the type of roll over, but any input is appreciated.
