The AC controls work fine with no problems; as does the AC.
I have not checked the hidden bottle in the bumper, but I will.
The vacuum line to the heater valve has a very tight seal and is in good condition.
The lines for the MAP sensor also have tight seal. Other than the idle, the engine runs fine.
There is one line that runs from the booster to the intake and it also fits tight and is in good condition.
At this point, it looks like the most likely culprit is going to the be manifold gasket. Suppose this is the time to go in depth on it, now. If I don't have a propane/MAPP torch, can I use something else?
