bigalpha
Moderator
- Tucson, AZ
yeah, the wire does NOT get wet with antifreeze, water, blood or anything else. I'll wrap it up nice and tight when i get home.
If there's a lot of oil around try checking starter.
I just went out and took some pictures ... in the process of scanning them, I realized that I think some of the fuses are wrong.
For example "HAZ/STOP 15" has a 25 fuse in it. Other than being dangerous, could this be a possible culprit for poor idling or parking light/blinkers issues?
sounds like vacuum leakI could cover up the IACV hole and the engine would idle down to about the right RPM.
Still no progress on the idling issue. I tightened the manifold bolts (a few were slightly loose) and that evened out the idle just a hair.
Unplugging/plugging in the IACV while the Jeep is running didn't change anything; same with the TPS.
Still idles at about 1500 in P and N; will slowly rev up to ~3k RPM and maybe bounce around a bit. Hitting the gas doesn't always bring it down.
I replaced the IACV and TPS already with no change in idling speed. Could a dirty TB cause this issue, even if the IACV is clean? I could cover up the IACV hole and the engine would idle down to about the right RPM.
What's weird is that when cold, I start it and shift into R and the truck will die but it restarts immediately.
