jeepsrock
- LA California
Damn problems never end... This time when i turned on the jeep instead on idleing at 700-1000 like it normally does it idled at 1500 for a brief 10 sec and went down . Even tho it went down--once i pressed the gas pedal the engine vibrated around 1600-2200RPM , this would only be felt inside the car and really not outside weather under or in the engine bay. Other wise the jeep drives ok, but around that RPM it feels weird. After cleaning he tps, o2, iac connectors it seems to idle a bit better but it still doesnt feel right at that rpm band (1600-2200) .
When you push the accelerator slowly in nuetral it feels fine as it increases but as soon as it gets to that rpm it feels as if there is a sudden tone change and shudder ?
I need a few suggestion before i give up and let someone look at it...its been too long this thing has been acting retarded.
Thru my other posts i have done the following, to help the sitaution..
1. Replace Motor Mounts/Tranny Mounts (helped for a while or rather hid the prob)
2. Replace Spark plugs / Wires (champion/bosch)
3. Repalce cap and rotor with one from napa
4. Changed motor oil / filter and tranny oil
5. Reset ECU
thx
pete
5. Reset ECU
thx
pete
