End of my parts stock...mj xj stuff
here is the list since some dickwad keeps flagging it...
Lot one small or cheap xj/mj/tj parts:
-xj mechanical clutch fans (i have 2) $5 each
-97+ Fan Shroud...missing top screw tab $5
-Stock xj downpipe...needs hanger welded back on, comes with 02 sensor that is newish $5
-Climate controls from a 99 xj...$10
-turn singnal and side marker lenses...new and old style $5
-manual belt tensioner from a 99 (will fit a lot of years) $5
-Stock ubolt plate set...very solid $5
-Throttle cable, cruise cable, kickdown cable bracket for 99+ manifold...$2
-stock xj shackle $5
-4.0 crank from a 2000 xj...will need machining. $10
-peugeot ba 10/5 manual transmission with bellhousing for 4.0. $20
-NP 231 21 spline input $25
-xj/mj tan hood in okay shape $10
-2000 xj cylinder head...needs a good cleaning. $20
-xj auto trans cross member $10
-xj manual trans cross member $15
-xj electric fan from a 2000...was only used for 3 months after purchase. Stock connector was cut off but you can splice yours back on it. $30
-99 PDC and harness...may have a few connectors cut. $5
-xj top radiator support $5
-advance auto xj radiator for open systems...used 5 months. $30
-2000 xj AC condenser...$5
-xj tan center console lid working latch $5
-upper radiator hose (i think) $5..was used 5 months
-xj water pump pulley $2
-xj stock tow hooks with brackets $20
-2000 xj electric blend door actuator $10
-87-96 rear wiper motor $5
-97+ center console support $20
-2000 xj piston rods (have 4 good ones) $10 each
-rebuildable 2000 xj engine block $20
-4.0 oil pan (not rusty) $10
-tan under steering wheel cover $5
-broken fog light $1
-1998 headlight switch $5
-alternator front and rear bracket set $5
-lot of misc working sensors $10...2 cps, 2 tps, one cam sensor, several other sensors included
-99+ intake manifold. $50
-97+ front clip wiring harness...some bulbs included (2 available). $10
-stock xj airbox $10
-fan clutch/idler pulley brackets $15 each
-engine side motor mount brackets $10
-aftermarket dorman exhaust manifold (few months old) $40
-1999 gas tank and fuel pump $20
-drivers side front gauge trim bezel $5
-older style front bumper $20
-stock front driveshaft new ujoints...may need centering ball $35
-durango upgrade steering box $50...was brand new. Has 200 miles on it
-HD steering box spacer...home made $20
-99 ac compressor working, but had a frozen bolt in it...should be able to hammer out and make it work $20
-washer bottle for 97+ $5
-power steering pump...broken outlet..good pulley $5
-valve cover $15
-stock 99 airbag $25
-passenger side front brake pad set...$5
-96+ throttle bodies $10 each
-extended front bump stops $5
-turn signal switch $5
-wiper switch $5
-good set of gas tank straps $5
- 99 injector/engine sensor harness...i believe its un cut $20
-poly RE conical bushings...larger size $5
-RE extended rear brake line $25
-1999 airbag computer $10
-1999 coolant overflow tank $5
-black radio bezel $5
-lot of fender flares $10
-door step trim panels $5
-Stock sway bar $5
-behind gauge bezel support for 97+ $5
NEW or MORE EXPENSIVE PARTS:
-new ubolt sets...full set for dana 44/35 xj rear with nuts $25
-New ubolt pair 2.5" ID...$5
-New Ubolt pair for dana 44/35 with no nuts $5
-single rear monroe shock for stock xj $20
-leaf centering pins $5
-zone bar pin eliminator set $20 with hardware
-misc ujoints $5
-front grille, fenders bezels, lights wiring for 97+ xj...primed. $175
-7" anti wrap perches $30
-stock leaf perches $20
-weld on shock mounts $20
WJ PARTS
-Main fuse box -$10
-sliding seat tracks $5
-power seat base $25
-dash $10
-CHrome front grille $20
pics of parts:
http://s528.photobucket.com/user/altrocker2/library/
same thing happened with my C10 for a while.....I hate CL.
Ill PM you for paypal. I can pick up at Johns house if hes getting other parts.
he will one way or another...if its not too late when i roll through illinois (or early) i will be meeting up with him. unless you want to stay up late and meet me and can deliver stuff to john :)
should know more about time frame when it gets closer....
If John will b at Sean's in July, I can get stuff to him then.
I wish I was, but another ill-timed vacation has us heading to Sedona on the 15th.
But if meeting Craig on his way out there doesn't work, it would be great if you could get the parts to Sean's, then I'd have additional motivation to visit him some other time.
That could work too. Im right off of 55 and 355 but float around like a bumb
This is unacceptable!
Her 50th birthday has been scheduled since July 16th 1966.
I highly doubt you had your trip planned that far in advance.
In my world you don't celebrate birthdays and holidays on the day they actually occur...
mac 'I know it messes with the space time continuum stuff' gyvr
