Mine did not go away completely until after multiple daily cycles, daily cold to hot, run up the RPMs, cycles, but each trip, or cycle it got better, till it just disapeared completely. I had already driven it as a DD for 3-4 years, 24,000 miles with the ticking, and tried every snake oil under the sun to clean it up. 3500 rpm (which by the way is 3.5K, 35K is 35,000 rpm) for about 30 seconds each morning did the trick!
assgas:
Talyn,
I read that PDF, it is about the newer HOs, and about carbon making the exhaust valves stick, it does not mention sticking lifters, although I wonder if they would sound much different, or if by the time one has happened, perhaps both have happened? I pulled pieces of solid carbon 1/2" to 3/4" thick out of the head on my daughters 89 jeep 4.0, when we pulled the head 2 years ago. And it was not the one with a ticking problem!!! LOL, It had a blown head gasket between #4 and #5 cylinder walls! Red hot glowing Carbon had burned through the thin gasket between the 2 cylinder walls!!! It was the only leak point in the head gasket!
5-90 is our resident Renix engine, and Renix jeep expert, 87-90 engine, so I suspect his feed back was had a much older source? Maybe he will drop in and find out if he recalls where he picked it up, and his version of the story.
But I will say this, both the gumout/carb cleaner to clean up the exhaust valves (2 hour soak, after loading it up at idle in the throttle body), and MMO in the oil, and then run the peyotes out of it, should be standard procedure for a sick 4.0 (or most engines) that have been abused by commuter, local driving on short trips!
