One big Taurus fan is like 17", but it does not good because the radiator is so wide. I've been through all this. The Tauruas fan pulls lots of air through maybe 40% of the radiator... thats it. Not good. The sides aren't getting cool.
You can do two side by side twin 12 or 14" fans, but still not covering the entire radiator, plus making a good shroud is hard. THREE 10" fans across is a really good move BUT...
My problem was my engine was heating up, and making my fans so hot... they would shut off and quit working due to the built in "auto shut off" when they get up to a certain temp. Double screwed! Hot engine, no fans!! It sucked big fat donkey testes, and runied a couple potentially fun weekends.
The solution:
On the inside, keep the mechanical fan.. WITH A SHROUD. With the stock shroud the opening suits a 14" fan blade... which is small. Most Flex-a-lite brand fan blades are 17,18" inch. Boo.
Flex-a-lite makes a plastic "nylon" low profile economy 14" fan that is only $19.00 and pulls a good bit of air. Perfect... bot her on there.
On the front PUSHING electric fans is the key!!
Becuase they are away from the hot engine compartment. My hood is vented and everything, my fans still quit working on those 95 degree August days when mounted inside.
I'm going to do my best to fit three 10" fans across the front, inside the grille recessed area. I will let you know how it works out.
I've done a lot of options, upgraded to a 3 core radiator... tried multiple electric fan combos. No luck yet.
I think the 3 - 10" PUSHER fans are the best bet,
along with a internal mechanical shrouded puller too.
