streetxj
- Pembroke Pines, FL
142rwhp/187rwtq Dynojet, 4.0 Wrangler, stock
151rwhp/183rwtq Dynojet, 4.0 Wrangler, NO air intake tube or filter-unrestricted--open TB(+9hp/-4tq)
144rwhp/175rwtq '97 ZJ 4.0
148rwhp@4700/187rwtq@3100 Land+Sea Dyno, '01 WJ 4.0 106k, K+N FIPK, HF cat, flowmaster
163rwhp/190rwtq Dynojet K+N Company Test, '97 XJ AW4 2WD 60k 2nd gear
171rwhp/199rwtq Dynojet K+N Company Test, +FIPK (+7.9hp/+9.19tq)
156rwhp/202rwtq ?Dynojet '00 TJ 31"
177rwhp/232rwtq ?Dynojet '00 TJ 31" + 62TB, CAI, EDGE Trail Jammer module (+21hp/+30tq)
Based on the 97 XJ readings with the FIPK, I would guess that my torque readings will be in the low to mid 200's and the hp ratings in the 190-200 range. I have the stock 1996 down pipe with the pinch/dent deleted, 2003 4.0 intake manifold with the thermotec heat wrap under it, 62mm ported throttlebody, precision auto fuel injectors, thundervolt 2.5 inch high flow cat with 2.5 inch aero turbine muffler which exits into a 2.5 inch pipe, that is adapted to a dynomax 2.25 inch tail pipe with 2.5 inch tip, 180 degree thermostat, taylor thundervolt 8.2mm ignition wires, jegs performance coil with accel cap and rotor, and stock intake system with extra large cutouts facing the driver side fender, K&N panel filter and intake tube entrance air silencer horn deleted. It has 160,000 miles, but it is a healthy engine. So far, I've ran 1000 miles on the Mobil High Mileage oil and it still smells like it just came out of the bottle and looks clean.
